Yeah, even on our Superstar, loads are shed when switching to generator or back to shore power.This may have been an operator induced error. Tried the on/off/on button pushing process to no avail. Only the front unit had the Comp error stuck.
The AC unit did reset on it's own after a time on 50 amp shore power.
Battery power is able to run the front unit which did not continue after pulling shore power. And Comp 1 & 2 AC are on Line 1. I'll have to spend some time sorting out what is allowed on battery power.
It may have been unhappy with us not shutting down the ACs prior to pulling the shore power. Too early start to trip home. Bad operator...
Generally the electronics in this coach do not like to be powered during power transitions. Even Generator to Shore causes delays, errors as sources are switched.
