Full Wall Slide
Your FWS is controlled by the HWH system so all the computerized stuff that controls the system is contained in the HWH control center/unit. I don’t believe there is a specific controller for the FWS like there is for each electric slide on the PS.
What is the reason for the question?
Thank you for the information.
Our Full Wall Slide was stuck out this morning. We were able to manually get it in luckily.
Another question. The back of the FWS would go in all the way but the front would still be out over 12”. Do you know what would cause that?
Wow! If you brought the slide in manually you did it evenly front-to-back which would have ended with the slide in evenly. If you used the HWH system and it brought it in unevenly as you say, you have a hydraulic failure on one side. You need to get to a shop that is familiar with the system.
