Question Greetings and we need help!
Hi my name is Jose Quintero and my wife's name is Jeana Quintero. We just bought a Tiffin Midas Class B + Rv 2026. Only 3 days old and the engine light is on. Does anyone have any idea what problem might be? We may have to take it down to our dealership tomorrow. Does this brand often have a recurring problem connected with the engine light?
You could disconnect the battery for a minute and reconnect and see if it goes away, HOWEVER, being 3 days old take it back to the dealer while the light is on.
You can get a scanner to check, decipher, and reset engine codes. Some are random, some for an instantaneous low voltage at startup, some are serious. If the CEL and code are damaging, the vehicle will go into limp mode.
Welcome aboard.
I am sorry to hear you are having an issue when your rig is just a few days old. As Boat Bum recommended, take it back to your dealer. That way there is a record of the problem should it reoccur.
Safe travels!
Don't clear codes! Doing so will hender the ability to troubleshoot the problem.
Soon after we picked up our new rig in 2021, we had about every light come on on the dash. I knew a guy at a local Ford dealer and he took care of us quick. Well it took a bit to find the problem. A wiring harness fell against the belt burning wires.
So likely the chassis is under warranty, so the chassis needs to be looked at. The RV dealer probably will not address chassis problem. An engine light is chassis. Best of luck.
You can buy an odb2 reader so you can read the error code. That way you can get an idea of what the problem “might” be and you can relay that to the dealer. They may have a quick solution. In any case they would have an idea before you got there. I have one and needed to use it several times.
