- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
While my heat pumps aren't bad the one over my bed can get into a "grind" mode where there is some vibration and it becomes obnoxious, otherwise it's not bad. Of my two roof unit setup typically my rear unit does the work probably due to poor placement of the sensor (thermistor) at the half bath wall so it's being heated/cooled by the rear unit. Due to the way Newmar runs the duct work where either unit covers the entire coach, last night I ran up the front temp 2 degrees higher than the rear so it would run. In fact the rear unit never had to run and I was comfortable in the bedroom and I didn't have to deal with the noise. So the lesson learned for me may be to leave the rear HP off and just use the front HP and it will adequately heat the bedroom as well without the overhead noise.
