Heater turned off!
Uncle Tuff
Carlsbad, California
Four Winds
Majestic
Ford
Ford Triton E450
Hello Fellow RV’ers!
I have a 2007 four winds majestic. I was using the heater last night while we were in Sedona and it was working perfectly. I was going off of the generator. I just recently got to Flagstaff and plugged in and turned on the heat inside and moving the fan started blowing out air but it wasn’t hot. Then the whole system shut down. I turn the thermostat off and then waited about five minutes and then turn it back on at the same thing, turning on for a minute and then turning off. Any ideas as to what it could be? Thank you for your time and input.
Find the reset button on the furnace. Not familiar with your unit. Maybe someone will come in that is. IF you are lucky, it will be accessible, unlike mine.
IF that does not do it, it is time to service the furnace most likely. 14 years old.
Thank you. It is strange. It was working fine. Then stopped.
I’m gonna try to reset it somehow. Thanks again.
