Hello From Hayden, ID
Sandy1943
Introducing Ourselves... Harry and Sandy from Hayden, ID.... new on here
Have a beautiful 2012 Arctic Fox 25R we may be selling so that we can move to a motorhome. Will be looking for ClassC 25-30’
5-10 years old. V10 and walk around bed with slide outs. Hope to find within short distance from Hayden.
Welcome to RVForums @Sandy1943. Great to have you with us and we look forward to hearing your camping stories and continue to share pictures as we love pictures :) Welcome aboard.
V10. when you find a coach, check the year of your coach for spark plug issues.
Kevin is correct. I have a V-10 in my Class A and found out about the spark plugs. Reading other forums the issue was resolved about 3 years after the V-10 came out. The reason for the problem was the head was not as thick as it is now and the spark plug threads would protrude a little into the combustion chamber. This would allow carbon buildup on the threads, then when removing the plug the carbon buildup would damage the threads in the head.
The procedure to remove the plugs is:
1. Vacuum the plug area and remove the coil.
2. Break the spark plug no more than a 1/16 of an inch.
3. Spray generous amount of carburetor cleaner or carbon remover
4. Let sit for 6 hrs or more. This will soften the carbon on the plugs.
5. Clean any fluid out of the cylinders to prevent hydraulic lockup.
6. When installing new plugs, torque to spec and do not over tighten as this could damage the threads as well.
