MarkMaxPayne
- May 24, 2023
- Beaverton, OR
- New Aire 3543
- 36'
- Spartan
- Fiat 500 Turbo
And on top of that, after those 2000-4000 cycles the batteries are not dead or near dying, they just only hold about 80% of their former charge so a 100Ah battery is now an 80Ah battery, which is still better than a 0Ah brick...Lithium are typically rated between 2000, and 4000 cycles. This is where things can be confusing!!! A cycle on a Lithium is based on a different concept. Although discharging one shouldn't discharge more than 80% the cycle is based on using 100% of the capacity! To clarify, if you bring a fully charged battery down to 50% twice that would be a cycle! Put another way using a 100 ah battery as an example and a 2000 cycle life battery your battery in theory would supply 200000amp hours before it would need replacement.
I think even without solar, Lithium Iron Phosphates are great for practically doubling your capacity for almost half the weight. Throw in there they recharge so much quicker, can handle higher loads, you don't brick them by going under 50%, and lasts so much longer before needing replacement -- the question then becomes do you want to spend that much more $ for all those upsides?
Best,
-Mark
