Question House batteries
I like my Battleborns, but there are several good brands now…
Oh. And you are able to use your Magnum with custom settings…
Ok, so if I go with lithium, can I retain the Magnum inverter and panel? Also, what brand(s) of battery should I look at/ avoid?
Sorry, but cannot speak to Magnum inverters. As for batteries I've owned both BattleBorn and Lithionics. The BattleBorns were akin to drop-in replacements with each battery having its own internal BMS. I was able to do my house battery replacement myself as it was very straightforward. The Lithionics are built like M1 Abram tanks and have an external BMS, but they are super $$$$$ and, with Winnebego owning them, options are very limited as to your dealer and service options. I love my factory Lithionics that came in my New Aire, but if I was building from scratch I would instead spend my $ on cheaper alternatives given the crazy $$$.
There are many challengers to BattleBorn at cheaper price points, but in many cases you get what you pay for in terms of internal components, robustness, quality, service, and warranty IMHO. There is a YouTuber (https://www.youtube.com/@WillProwse) who tears into LiFePO4 batteries as he reviews them. Here is the link to his tear down of BattleBorn: . Only really interesting when compared to his tear down of others you may be looking at.
Best,
-Mark
I believe they will work with Magnum. I still have the little Xantrex 2000.I am looking at getting a Magnum or Victron inverter, so Ican run a/c on batteries, and so ags can be controlled by demand.
And on top of that, after those 2000-4000 cycles the batteries are not dead or near dying, they just only hold about 80% of their former charge so a 100Ah battery is now an 80Ah battery, which is still better than a 0Ah brick... ;)
I think even without solar, Lithium Iron Phosphates are great for practically doubling your capacity for almost half the weight. Throw in there they recharge so much quicker, can handle higher loads, you don't brick them by going under 50%, and lasts so much longer before needing replacement -- the question then becomes do you want to spend that much more $ for all those upsides?
Best,
-Mark
Well not exactly! Using a Lithium battery when it's capacity is 80% is a fire hazard. I won't get into the specifics, but you should do the research to avoid burning down your RV!
Further more, what big business and governments will do to acquire the minerals to make these hazards is downright demicide!!!!
Nope! Won't be a part of it!!! I guard my sanity!!!
Please do share links to such research on LiFePO4 batteries being a fire hazard as you describe.
Best,
-Mark
It's been a while! Probably 2018. Some references were books, but some were online!!! I will spend some time looking.
Best,
-Mark
I too would like to see that.
Ditto on wanting to see recent research.
Battery technology is quickly changing and with larger volumes of batteries in use, we now have the ability to have a larger set of real world data and not just theory based on lab sized sets of data.
I understand that Lithium Ion batteries have a higher risk of run away heat and is the battery that is seen in use in highly publicized pictures, but Lithium Iron Phosphate (LiFePo4) has been a much safer and stable composition. But LiFePo4 has a lower energy density than Lithium Ion.
I know that the battery university website is shrouded by controversy, but the data is valid. This blog also has valid data, but is jaded with sales in mind!
Qnovo | WHAT HAPPENS AFTER 80%?
So much of my data came from research I did while experimenting and building my 90 ah 24v lithium-ion packs(2) for a pop-up slide in camper build, to use for a summer of traveling! Ion batteries were the choice for size and weight.
I tell you this as a preface to this subject. LiFePo4 were avaliable, as well as LTO, the hazards are much the same in all but the LTO, but that's another story!
That YouTuber that talks and tests lithium agree in the context that manufacturers can't make parts that don't vary. He points to quality as a measure that you get as a minimum what has been advertised. But in the world of quality, the cells must be classified through testing, not only capacity, but resistance. The parameters are grueling and extensive. Mismatched cells can be disastrous. So at manufacture date they are matched as precisely as humanly possible.
Over time imperfections in material start to show their ugly head. Cells become less matched and don't charge equally. BMS to the rescue!
Two types of BMS are produced, active(only the most expensive packs have them), and passive (most common)! To answer Neal's question 80% charge only works to save the batteries if the BMS is active! A passive BMS requires a 100% charge to equalize the cells.
BMS literally can claim savior status when we talk lithium. Without them you would not find lithium on the shelves! But they can't change the chemistry that makes them nessassary. Over time the unbalanced cells (we are talking physical characteristics) can't be overcome with balancing schemes. When the differences in cells become pronounced enough, we get to that 80% number, and quickly escalate.
So you ask, what happens at the 80% number that makes a fire Hazard?? The BMS is built to negotiate a new battery!
People, not educated enough to deal with the issue, continue bringing the pack down to 20% charge! They complain that their battery no longer makes it the expected duration.
BUT!!!
Internally some cells continue providing as usual, while those that are struggling with increasing resistance can never catch up! They try but to no avail. The enevitable gets closer, then on one cycle the slacker cell is brought to "0" volts. Then it reverses polarity!
Nice story Kevin! What's the point!!!
Well that cell becomes a dead short! Yes! and the entire battery works in unison to feed that new demand. One they can't fill. The shorted cell overheats to runaway temperatures and turns into a bottle rocket. But it doesn't stop there! The cell next door quickly overheats, and the chain reaction can't be stopped!!!
now I have seen LA and other chemistries short out and start fires. However nothing has matched the intensity of a Lithium fire!!! Literally fire departments learn to try and cool the fire because they are the fuel and will continue until there is no more power.
I gave you a few resources! My experiment told me what I needed to know! Lithium is far from new technology! If you're reading this likely the discovery was made before you could count! I know it was before I could! It simply was learned how it could almost be controlled.
Don't look for advancements that will make it truly safe. Not in yours or your offsprings life! Not going to happen!!!
Sorry, maybe I'm missing something here. Isn't that article all about Lithium Ion batteries? A completely different chemistry than the Lithium Iron Phosphates we've been talking about? I'd love to see similar articles/data attributed to the LiFePO4's being discussed in this thread.
Best,
-Mark
The electrolyte is quite different between lithium ion and lithium iron phosphate.
As I understand the electrolyte in lithium ion is a liquid, which in extreme heat will boil off, then that causes a chain reaction.
But the electrolyte in lithium iron phosphate is not a liquid that will boil off, preventing the stereotypical lithium ion battery fire.
Just my $0.02
Not a battery engineer, just someone who likes to read and understand - an analyst who likes to understand various perspectives and try to find the truth.
Just my $0.02
Of course! In the short search for resources to share, many of the older data has been scrubbed. I won't go into why I believe that is, although relevant!!!
But lithium is lithium. The original lithium never made it out of the lab. Seems that pure lithium is a powder keg! But searching the internet comes up blank on that research! Guess they don't want that history out there while they push this power storage medium!
So with each version, the are less volatile, and less energy dense. LTOs are very stable, with almost lifetime cycle life. However they are heavier, and considerably larger.
The size and weight increases along with decreased energy density are from the lower lithium content.
My prediction based on my assumption there will be an even larger number of fires due to aging number of batteries, nothing else, is a move to the LTOs with the promise they won't burn down.
You may remember the serious fires, but those new to the game will tell you there is a big difference in chemistry, though your research is burned into your memory!!!
and no! The difference is in the cathod and anode, not the electrolyte.
When I studied, there was: lithium-ion, lithium-polymer, liFePo4, and LTO. At that time all the data circulated freely on the net! Where and why did it go???
Nope! The only difference in the chemistry between them is the volume of other minerals to make the lithium less volatile. Does that make them safe? Well safer! Do they have a larger cycle life? Yes! Does that make all cells age equally? No! We are seeing evidence that that aging still results in 🔥!
You must do what you will do! I will not go down with the karma from my lack of action!!! I release it!!!
Currently have the 8 flooded batteries and was wondering, when it's time to replace, if I should go with lithium or just agm batteries. (No solar) We seldom boondock, but were stuck without power for a few days from the hurricane in SC, so I'm starting to think ahead. I have the magnum panel with SOC display but not sure it's compatible with lithium. Also, with lithium, I assume they are all 12v?
Here is the OP - let's get back on track.
For what it's worth...a friend was recently booted from NIRVC storage in Lewisville for his new Lithium Iron Phosphate batteries. He was told he could only keep his coach in their storage facility if he purchased his batteries from NIRVC and they installed them. I'm guessing where you buy them affects flammability. Interestingly, the owner keeps (and charges) his Tesla in the same building.
Crazy... Sounds like a fishing expedition for even more $. What if factory installed? Lol.
