HWH Control box
mansracing
Rogers,MN
Essex 4531
Spartan
X15
Stacker Trailer
Does anybody know where the HWH Control box is located? MP85.102A
I'm Trouble shooting one of the Jacks indicator Red lights not coming on.
2018 Essex
Thanks
Randy
It’s more than likely the pressure switch at the base of the Jack. Does the Jack go down and stop when it in the correct leveling position?
Yes the jack goes up and down fine.This system uses a two wire magnet switch on the jack.All it does is switches a ground and turns on the red led for that jack.I unplugged the switch and hooked the two wires together and even tried hooking to ground and still nothing.The HWH troubleshooting guide says next to go to the control box but I can’t find it.
The control box MAY be next to the pump beside the generator.
You could call AZ PETE. 602-549-3638
He works for HWH and is very helpful. Chances are you will get his voice mail but he will return your call.
