RKins
RVF Expert
- Nov 15, 2019
- Sarasota, FL
- London Aire
- 40'
- Spartan
- 6CTA 8.3L Cummins.
- 2008 Jeep GC Overland
How did you get the old switch out and put the new one in as I have the same problem, and need to change mine between the drive and tag axle.Just to "put a bow" on this - pressure switch is changed and the jacks work as designed!
My understanding is that the ability to raise one jack individually would also allow you to tweak your chassis, so instead you can manually raise either end or either side evenly. Looking at the arrows that way they make sense.I have the exact same issue at times. I just recycle the auto level sequence and it has always self corrected.
I guess I need to read the manual again but I can never figure out which arrows to push to manually level the coach. It does not seem very intuitive to me. If there was simply and up or down arrow for each jack it would be easier to understand. I just use the auto level for now but if I wanted to raise the wheels off the ground I would need to use the manual function.
