Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I am ever mindful of my inverter output. To be honest I would not be able to use it. My single coil unit is 1400 watts max. and most of the time I use it at the start-up setting of 1100 or step it down. My system is set with an Air switch(180 amp breaker). Because the cook top is an inductive load there is a start-up hit but it seems quite low in my case.
Only two items in my rig are not used on inverter are the A/C and the air fryer/ micro.
To keep with this post linage the circuit use is a 20 amp dedicated circuit. If the kitchen circuit you want to plug into is dedicated 20 amp then it should be fine. Even if not dedicated and is 20 Amp you should be ok as long as Like @MapNerd posted you don't try to overload the circuit.
