Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Both. It’s an amperetime 200ah. And a 200a bmsTwo batteries (at 12v) will become 400ah of total capacity, which would double not only how many amps can be pulled at once, but also effectively double your capacity (How long you can bookdock, for example)
I need to make sure we are talking the same thing. Is your battery able to have a 200amp draw? Or 200 amp hours of capacity? Or both?
Ok. That works. I found the model online. That should do well for your TT, especially without an inverter.Both. It’s an amperetime 200ah. And a 200a bms
It is a amperetime 200ah with a 200a bmsWhat model battery?
No I’ve taken up enough of your time.Ok. That works. I found the model online. That should do well for your TT, especially without an inverter.
Any other questions?
I haven’t installed it yet. Planning on putting it as close as posable.I have a question!
How far from the battery are you mounting the shunt?
