TJ&LadyDi
RVF "Dinosaur"
What are friends for, Bill?You all scarred me into purchasing a spare ? Thanks
...this fuse should rarely fail and I would be concerned if it did.
It was the convection oven and dishwasher also running. Everything had been going so smoothly we forgot we were on 30ampsApparently if you throw the right number of Watts on the line it can get up in amps quickly. I don't know the math but I know @MapNerd used an Air Fryer pushing 1700W on the inverter line on top of whatever else was on the circuit.
And, did you order the Riedon version? If so, you got the same substitution I did. Nice $50 upgrade at no extra charge!Fuses arrived today....brand was Littlefuse.
And good to know what could blow it.
Yeah but I was on 30amp. The wings my wife makes in that air fryer are totally worth it. Had more of em todayMy fuse blew while using the batteries boon docking. MapNerd yours blew while hooked to shore power? I wouldn't think it would blow since you're using shore power and not running solely off the batteries. I'm not sure mine would have blown if the stud bolts holding the fuse were tight. We had a griddle, microwave, TV and maybe the cook top but not sure about cook top. That's probably stretching it a good bit. Generator auto start was set wherever Newmar or whomever set it. I'm not exactly sure what the setting were.
Mine just arrived, same update @ n/c.And, did you order the Riedon version? If so, you got the same substitution I did. Nice $50 upgrade at no extra charge!
