Inverter issue
KJ2019RoadtrekZion
Hello,
We have the 2019 Roadtrek Zion. Lately, when having the RV plugged into shore power and the inverter on after a couple of hours the inverter will begin to have what I assume is an alarm sounding and will shut down the inverter system.
I took it to an Roadtrek shop to look at it. They had it for two weeks and could not replicate the issue. As soon as I brought it home and plugged it in again I had the same issue.
The shop's suggestion was my electric coming into my home. I checked with the electric company and they said it was within the normal 120 voltage. As well, I have had it plugged into this line for the past two years we owned the Roadtrek and never had this issue prior to April of this year.
Anyone else had this issue or thoughts?
Thank you.
Turn off the breaker feeding the receptacle that you're plugged into and pull it out. Check to make sure everything is tight and no issues back there, then check for proper voltage.
Why would you want to use the inverter when plugged into shore power?
The most likely reason the shop can't duplicate the problem is they know better than to turn the inverter when plugged in to the grid.
