Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
There might be a paper in one of your wardrobes with Part Numbers for your Leveling Jacks. You can probably tell from this the size...but it doesn’t clarify the potential for clearance issues.That’s what I read about my leveling system:
SnapPad HiWay
Made to fit on HWH® levelers, the SnapPad HiWay product line is one of our most varied.
“HWH® jacks commonly come in three different sizes - 8", 10", and 11.5" - and the different sized feet are often mixed together in different configurations. That means SnapPad HiWays are available in 6 different packages!”
Looks like diving under the coach is in my future? ?
Update: I have noticed significant wear on thre front ogf the right front pad. I don't see how the tire could reach it, but my concern and the advice from snap pad was to remove the front pad for safety sake. hey are currently designing another pad which may work better in this application (i.e. on the BayStar). I r4moved the front two pads and left the rear ones on.I have them on my Bay Star. I installed them by myself. No problems, no contact with any other part of RV.
Good idea, anyway. I found an electrical conduit rubbing against my brake line. Another spring project.That’s what I read about my leveling system:
SnapPad HiWay
I agree with Neal, if possible have someone else measure. But, as a FYI my 2014 DS 4369 has 11.5" round front pads and 13.5" round rear pads.Since I’m not in a condition physically to crawl under the coach and measure the size of the leveling pads:
Does anyone know what size Snap Pads l need for my 2015 DS?
I read that some coaches with our leveling system have mixed size pads?
Paul, you are right. I measured them, and the front ones are 11.5” and 13.5” the rear ones.I agree with Neal, if possible have someone else measure. But, as a FYI my 2014 DS 4369 has 11.5" round front pads and 13.5" round rear pads.
Paul
www.1999southwind.com
I have the SnapPads on my 2019 4018 DS, they work well and are easy to install. With that said, double check the fit before you buy. The 43' Newmar uses a larger rear pad than the 40' and SnapPad has not offered a pad that size yet.That’s what I read about my leveling system:
SnapPad HiWay
