It’s not doing it, I think might have install a battery chargerMost power hungry newer towed vehicles are going to need a 12volt charge line to keep the batteries up while being towed. Do you know if your harness in the Jeep is doing that??
Thanks!!! I'll pay more attention next time, maybe that's what I'm doing wrong.I have a 2020 Jeep Gladiator (basically your Wrangler, with a truck bed) that I pull behind a 2021 Newmar Superstar, using a Ready Brute Elite II towbar. It's all wired with a CoolTech harness, which involves splicing into the Jeep's existing wiring. It completely (physical air gap)isolates the Jeep's electrical system when towing, forcing power to come from the coach, and thus insures no drain on the Jeep battery while towing.
First time I towed, I arrived with a dead battery. I'm talking dead to the point that Jeep replaced both the main and the aux batteries under warranty.
Ultimately, I have developed a theory which may or may not be of value for the OP:
The Jeep has a start button, not a keyhole slot. During the hookup process, there is a point where you turn off the running motor. You push the button, and the motor stops. Just like it's supposed to do.
But, because the button is located behind the steering wheel in your line of sight, you fail to notice that the ignition did not go to "OFF", but rather it went only to the "ACC" position. You continue through your hookup checklist, and away you go, with the ignition in "ACC" instead of "OFF". Your Jeep battery is thus powering who knows what until you arrive at your destination with a dead battery!
I haven't had a repeat occurrence since I began paying strict attention to the ignition switch reading "OFF", like it's supposed to.
Hopefully this simple fix is your issue, and prevents you from having to install more gizmostats into your system!
__________________
