Kitchen water pressure
AbdRahim
BayStar 3626
37’
Ford
V10
None
Still learning this coach. Anyone with a BayStar have low water pressure at the kitchen sink? Even at initial or static (Park pressure) 55 psi, the kitchen sink faucet fully open runs about pencil thickness of the water stream. I know most modern faucets have resrictors in the faucet tip. This one seems to be in the hose that the sprayer attaches to. Has anyone been able to remove it to get strong water pressure in the kitchen?
Do you have a pressure regulator between the city water and your fresh water tank? If so, what is it set to? Try 50 or 60. When is the last time your house filter was changed? Lastly, what is the pressure with water pump vs. city water?
has it always been that way for you or is this a recent development?
Always. Coach is brand new, less than 4 months old. Pressure set to 55 psi. Same occurs with no regulator inline. Pressure is good in the bathroom sink. Toilet is moderate. Filters are brand new.
I’d go under the sink and remove the faucet and hose. Maybe there is a cover that Newmar forgot to remove when installing it?
don’t know this to be the case or not but there may also be a cutoff valve under the sink which is not fully disengaged. Worth a check.
There could also be construction debris obstructing the aerator.
Yes, take the aerator apart and see how it does.
When we bought our old coach every aerator was clogged (even the one on the black tank flush input). The Kitchen sink has a pull out spray head and it took some finagling but I found a screen where the wand and hose meet. Had to order replacements from Moen for that one.
Our Bay Star definitely has lower pressure at the kitchen sink than other inside faucets. But it isn’t pencil thin. It also improves when using water pump over park water. Like others said, something could be junking up the aerator.
How are the other faucets?
You can get under the sink and disconnect, check things, etc. It's a very basic household fixture you could even replace if you wanted.
Need to check the inside diameter of residential kitchen faucets. The orifice in the sprayer/faucet hose is very small (narrower than a pencil).
Not yet. My guess, so far, is that the drop to 20 psi at the campgrounds, when the faucet is opened might be part of the issue. The onboard pump may maintain the 60 psi with the faucet open. The kitchen faucet seems to be the furthest from the water inlet, so there may be a further drop in pressure. Just a guess. I will have to watch this. I made Newmar aware of it and the suggested perhaps a problem with the inlet check valve. If I do not find an answer, I will have it checked at the Service Center next year.
Pretty strange. We actually always use the water pump. We’re away from the coach today but when I get back I’ll flip to city water and see if I get a similar experience. If so, I’ll take it up with Newmar when I’m there at the end of the month and see what they say.
Interesting. I only use the pump when on the road. I figured why wear it out faster when city water was available. Now, though I run through a tank or more during the summer just to keep the water in the tank fresh and to keep the gaskets in the pump from drying out. In the previous coach I found that prolonged lack of use of the pump caused it to leak at the bottom. Leaking stopped when I started using it periodically.
I always filter and fill the fresh tank and live off it until I need to fill it again. I know what I have when I do this. I travel with a full tank too.
Glad to see this thread. We just purchased a new Baystar. We're having the exact same problem. Weak water pressure at the kitchen faucet. The aerator
was junked up, I cleaned that. I even purchased a new sprayer, which helped a bit. Using the onboard water pump helps too. So, I am thinking the faucet
cartridge might be clogged with debris so I'm thinking of disconnecting the lines to the faucet and blowing it out with some air. If anyone has solved this
I would love to hear how. Tried to get the dealership to look at it but "they are too busy." Not happy about that. We do like the motorhome, very nice.
Not solved yet. It is on my punch list for Newmar. If I get there before you, I will let you know.m I am not going to mess with it while it is under warranty. Snowed in right now - 22 deg F. That is the high.:cool:
Good idea. I may stop at their plant in Indiana sometime. I'll keep you posted too. Thanks. Wow...22 is cold. Stay warm!!
