Lead Acid to LiFePO4 Conversion
JayJay11
Jayco
Jay Feather 23b
We've had our Jayco travel trailer since 2020 and have logged 30K+ miles with everything stock. This year we are taking it to Alaska and I want to convert the lead acid deep cycle battery to a LiFePO4 battery (12V 100Ah or 150Ah). I think I want to permanently mount it inside under the dinette bench, which is open to both side storage compartments, and remove the current box holding the lead acid battery giving me more tongue space. In addition to charging this new battery using shore power (when available) and future solar panels, I also want the tow vehicle (Chevy Express van) to charge the battery while moving. Currently blade #4 in the 7 blade connector provides power that charges my lead acid battery. I have learned that I will need a DC to DC converter for the LiFePO4 battery, but will need to learn about voltage drop and the gauge of wiring, and also if others use the center pin #7 on the connector for this power (in lieu of reverse lights). I assume many people have made this kind of change (Lead Acid to LiFePO4) and I am looking for existing threads with this kind of information OR other resources people have found helpful. Thanks in advance!
I should have searched first. I found this helpful link:
Their is a discussion on this on another thread. Some are using a LI-BIM 225 replacement for the standard battery isolator. I just did a video on a "
Automotive Digital Timer Relay Board DC 12V 20A 1500W Relay Module with Dual Time Display, Timing Relay Switch ON-Off Control Support Cycle of time Time Delay for Car Vehicle (DC 12V). "​
It is about a 12th the cost and is not Mechanical. I am playing with it now and will update if it actually does what i think it will do.
