Lithium batteries solar charging
ShadyLedge
looking at purchasing a 2021 as agile. Will the 330w solar panels keep the lithium batteries charged? Or will I need to be continually on shore power to charge? Thanks
Listen! You need to determine power usage,to know if your solar is enough.
My answer was yes to both questions.
If you watch your power consumption it will do it's job. If your battery keeps loosing power daily,use less power.
You will find out quickly enough! You will then have the option to add more solar, use less power,or top off when needed!
How you manage the power will determine the outcome!!!
