Question Lithium ion batteries
sheridany
Orinda, CA
Question of the day. When will lithium ion batteries be available on all Newmar DP? It is now standard on the KADP for 2021.
Is it worth it?
If past practice is any indication, a new feature usually works its way down the model list a year at a time. There are times, however, when Newmar has introduced a feature at the top end and subsequentially made it standard across the board within a year or two. My WAG is probably 3-5 years for the whole lineup with the possible exception of the Kountry Aire and Ventana.
Is it worth it? If it became standard, it would be. As an option, it would depend on the price they set. For me, it is a bit too early to tell.
We have installed 600 amp of LiFEpo4 in the CS. I find them to be a good (not economical) upgrade. Runs front A/C and residential fridge for up to 5 hrs with solar help. AND they charge relatively fast, with no maintenance. We have found them to be less hassle than the conventional batteries. We camped for a week at the Balloon Festival last year and did not run the Generator once.
Did you just do the battery replacement or were there other things you had to add/change?
We did add 1300 watts of solar and a 3000 watt Hybrid inverter along with the 600 amps of LiFepo4 batteries. We have all the electrical power we want for our purposes, and then some. The front A/C we added a Soft Start so we can run that unit on batteries only for a considerable time if needed.
@JoeHogan - that really sounds like all I would ever need on mine. Did you do anything to the battery bay to protect the batteries?
Following....as I am looking to replace my 8 lead acid batteries with 8 battleborn in 2021...
Always like to see lessons learned.
The battery bank is Two 300 amp packs, both with internal BMS. One pack is exposed to the elements in the stock tray, and the other in a basement locker. I have noticed that the Pack exposed to the elements does get hotter right after we stop as the engine and exhaust are in close proximity. If I do this again I would put all the battery packs in a basement compartment.
Thanks Joe. My plan is to insulate the battery compartment (at least the best I can) and see how that goes. It is not near the engine, so not too worried about heat and we don’t tend to travel in the extreme cold, so not too worried about that either. I could add a small heater if needed.
Here is a picture of my installation.
i have had lithium over a year now. Dont have an insulted compartment and don't think I will ever need it.
The cost difference is my holdup. To change 8 LA's to Lifepo4 based units will cost me about 4K or more, and they will last about 10 years, so that is 400+ a year. I can replace all 8 LA with the direct replacement for 800 and change, but should do that every 5 years. So 1600 over 10 years versus 4000.00 over `10 years, sorry just aint going to spend that kind of money because, it just won't pencil out. Now if I install Solar at the house, then would go with AGM's at least. The cost structure needs to come down into the realm of possible for me. Of note, NO Lifepo4 based batteries are manufactured in this country, they all come out of china, partly due to manufacturing costs, and partly due to environmental regulations. So exactly why would you buy them from country who has publicly stated, they want to end the United States, and please don't' forget the nice present they gave the world called COVID-19.
Corey, did you make the bars that connect the battery terminals? Did you just buy copper bars, drill holes and cover with heat shrink?
Rich
that is exactly what I did.
Cool. What Is the guage/dimensions of the bars and where did you get them?
LTO levels the playing field. The only lithium battery I would consider.
McMaster-Carr
Multipurpose 110 Copper Bar with Rounded Edges, 1/8" Thick, 3/4" Wide, 3 Feet Long
McMaster-Carr is awesome. I can’t stop giving them my money no matter how hard I tried. Whoever built that website did an excellent job.
Thanks Corey. Looks very neat...which is one of the many reasons I would like to ditch my lead acid.
Thanks
Rich
