Just George
- Jan 3, 2020
- Texas
- Dutch Star 4369
- Freightliner
- Cummins ISL9 450HP
- 2023 Silverado
If you have MCD power shades in your coach I'm looking for some input on how Newmar has mine set up. I'm also looking for any experience out there in altering the shade controls into and alternate configuration. This will be a bit long but I'll explain the current shade labels and control as delivered in my 22 Dutch Star, then the configuration / control that I would like to get too. Any suggestions and or solutions would be greatly appreciated.
First off I'll start with some terminology:
The coach has two types of shades / shade material. MCD calls the shades you can see through "Day Shades" and the shades you cannot see through "Night Shades".
Newmar (per the various dash switches) calls the shade you can see through a "Visor" and the shade you cannot see through a "Shade"
The shades can have one of two different motors.
Motor A = a power shade with control via a toggle switch or other means of manually applying voltage to raise and lower the shade.
Motor B = a power shade with control via the MCD remote which is a RF type remote.
Per MCD, a motor with remote control cannot also have a manual switch control (i.e. to allow the remote OR the switch to raise and lower the shade.
So now to my problem and the function I would like to get too.
When driving, and the sun is basting into the driver side window and or the passenger side window, the "Visor" switch on the dash / passenger arm rest will raise or lower the "Day Shade" i.e. the shade you can see through. As a "Visor" this shade is useless as a football bat. It does not block the sun from your eyes and the heat that is created from the sun shining through the window.
In my coach the windshield shades are controlled by a switch on the dash. No problem there except once again the "Visor" switch controls the "Day Shade" which is useless for blocking the sun from your eyes as you drive. So solving my windshield shade name issue appears to be straight forward, simply swap the switches between the two windshield shades so the "Visor" switch actually controls the "Night Shade. I have not looked at the wiring yet but this seems to be the solution for the windshield shades.
Onto the driver and passenger window shades. So it's the same situation in that the "Visor" switch is controlling the "Day Shade" and I want it to control the "Night Shade". The twist is the "Day Shade" on the driver and passenger windows have motor A, i.e. manual switch control only, and the "Night Shade" on the driver and passenger windows have Motor B, i.e. remote control only.
My questions to the forum:
- Are your shade controls the same as mine? i.e. Perhaps Newmar just has the wrong shade in the wrong spot in my coach?
- Have you set up your coach shades in a way that you have control of the driver window and passenger window "Night Shades" while driving?
Potential solutions I've thought of are:
- Swap the shade material so the "Day Shade" material is on the "Night Shade" roller / motor.
- Add a couple TBD RF control / switches such that I have an additional RF switch for the driver and passenger "Night Shade"
- Post the RVForums to see what others have done.
Sorry for the long post,
Your comments and suggestions are greatly appreciated,
