Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
Apparently. Michelins don’t like to sit.I think I posted this somewhere before, but not sure where.Interesting. There are quite a few complaints over at IRV2 about Michelin and sidewall cracking. I guess the saying, YMMV applies.![]()
Regarding chemicals to keep sidewalls from cracking, a Bridgestone tire engineer made the same statement during a conversation as above regarding movement. The heat and movement redistribute preservative chemicals in the tires and keep sidewalls from cracking.Moving moves the lubricants in the rubber, I am told, preventing the outside from drying out. Michelins are very dependent on this movement apparently.
I think UV protectant such as 303 is ok, or hopefully even beneficial, especially for older tires, but the goo that just makes them shiny (detailer stiff) also makes dirt stick to them which may act as a desiccant. Living on a dirt road, I avoid stuff like that.Speaking of chemicals, I heard applying "treatment" such as to gloss up the sidewalls post detail is not recommended and there was even chat it voids warranties. Anyone know anything about this? Maybe tires that have had this bad cracking have had something applied to them during their life?
The engineers obviously have way superior tire knowledge than me it’s just hard to wrap my pea brain around “movement equals less cracking”Regarding chemicals to keep sidewalls from cracking, a Bridgestone tire engineer made the same statement during a conversation as above regarding movement. The heat and movement redistribute preservative chemicals in the tires and keep sidewalls from cracking.
The way he explained this to me is that the chemicals in the tire will settle when sitting for extended times. Not sure if the exterior of the tire when exposed to UV would flash off the various compounds or not. He did say that exercising the tire and bring the tires up to operating temperature helped redistribute the various chemicals in the tire sidewalls and bring the compounds to the surface of sidewalls.he engineers obviously have way superior tire knowledge than me it’s just hard to wrap my pea brain around “movement equals less cracking”
I came up with the same values based on my previous four corner weights of a couple years ago, and drove with those pressures for the last 15,000 miles or so, but I recently upped my rears to 100 and fronts to 110 because I decided I didn’t want to run at the minimum and I want to account for load variations, and it doesn’t ride noticeably different. Not really a scientific approach, but until I can get a current weight that’s what I’m doing.100 lbs on the steers, 95 lbs on the rears. Weighed coach and used Michelin's inflation table to determine. Also l drive slow. Usually around 62 mph. Also tried to drive monthly in the off season. FWIW, they looked okay until last year. Seemed to age a lot in year 7.
They don’t explain the chemistry or physics of it here but they do discuss the issue in the Michelin Tire Book, page 8:I would still suggest, and like to hear what Michelin says, send pictures to the RV group and see what they have to say about this, what causes it, etc. I've spoken with them before long ago, not hard to get in touch with and was easy to work with.
It depends if "brand" gives you peace of mind. Also take into account the company's reputation, experience, time in production of tires, etc. etc. All elements an owner has to weigh.but is it worth the added cost?
That was definitely crossing my mind…On the flip side, if you save all that money you can justify $5K for a pair rettrobands![]()
