Need to replace my waterpump
Racechaser
Columbus, Ohio
Forest iver
Zinger RL
26 Ft.
I have a 2008 Zinger and the waterpump is going south without me! How do I size a new pump? I see that I can get a pump from anywhere from 3.5gpm to 7+gpm. The TT has one shower, two sinks, one toilet and an outdoor shower(which is never used). Any advice would be greatly appreciated!
I think it will be your personal preference. If you can access your pump get the numbers off of it and get one at least the volume of it or larger.
If I had room where the pump sits I would go bigger! Why? What happened the last time you opened the tap full bore? As I recall the difference is only an inch or two and the pleasure when trying to fill a bucket immeasurable!
Yes stick with an RV pump, they will all supply the same pressure, just different volumes.
