fireball26
- Sep 3, 2020
Fireball,HI all i have a 1983 fleetwood and i need to get it started can i do that with 1 battery, it had 3batterys, i have 1, one cable is on right side of solenoid from + on old battery
i put 2 batterys in but all i get is headlights no dash no turnsig and will not turn engFireball,
I'm afraid there is not enough info for someone to help you. But basically, if you don't have enough battery power (1 vs 3 batteries) you may burn the starter $$$ if your voltage is not adequate to supply enough power to turn over the engine. Just guessing?
that is standard in most gas rigsI’m thinking that 2 of the 3 batteries are house batteries and one is chassis. I had a 1992 Fleetwood and that was the setup.
