BGMAC
RVF 1K Club
- Jan 28, 2020
- Cypress Inn, TN
- Forest River
- Georgetown XL M-369DS
- 37ft
- F53
- Titan V10
- 2024 Chevy Colorado
Welcome to the forum. Best of luck on your search. I looked around the web for campers under 7000lbs. I don’t like towing a trailer at max weight. It tends to be uncomfortable towing especially up and down hills.
here is a listing of several trailers that might fit your needs:
Travel Trailers Under 7000 lbs - 13 Top Choices!
It used to be easy to find travel trailers under 7000 lbs, but weights are increasing. We've found 13 campers that are towable by 1/2 ton or SUVs!scanneranswers.com
below is one where the trailer dry weight is 4800 lbs with GVWR of 7000lbs and it has your fireplace.
Model Not Found | Lance Camper
The requested travel trailer model could not be found.www.lancecamper.com
Now I don’t know much about the trailers. Maybe others can chime in.
good luck.![]()
Welcome to the forum. The rv dealers are seeing a surge of sales activity as a result of people look for alternative ways to travel. I would start on line and find the rv that you think would meet your needs budget etc. It’s a bit of work but you will become more informed along the way. Ask questions here on the forum as the forum is adding lots of new members every day who will be able to answer your questions. With that, you should be able to narrow down your choices and if towing that can be figured out. One thing you might want to try renting using websites like outdoorsy and that might help you determine what kind of RV you want. They bring it to you and set it up. RV ownership is a journey and being informed will help you enjoy it that much more. Good Luck.
Hi @MicaPica and welcome to RVForums. I think you'll have fun once you make a purchase and get to use it. Another of our members, @ARD, bought a monster Class A and hit the road. I think the only instructions she had was the ones they gave her as they shoved her out the door.
And she's doing fine. Well, the last time we heard from her she was going OK. Wait, come to think of it, has anyone heard from Ard in awhile???
