GypsyR
RVF VIP
- Mar 15, 2021
- upstate SC
- Kountry Aire
- 38 feet
- F53
- Matrix
I still don't really see the advantage of an M18 "inflator" over the M12. I suppose the stronger battery is matched with a stronger motor so as to inflate things quicker if you are in a hurry. They both only go up to 150 psi and the M12 is certainly lighter and more compact. I'm all about options that are lighter and smaller when loading my coach down with stuff. I don't see myself being in a rush to add a couple of psi. I usually hook it up, set it, and then do some walk around inspecting or something until I hear it stop. I'm not rushing any pre-trip prep work, I've learned that lesson.
My coach stays literally three feet away from my home shop "paint a car/run a blast cabinet" compressor. So on my shortish road trips an inflator does for me. Others have pointed out they want blow things out/clean with compressed air and maybe some other similar stuff when away from a home base. For them an actual compressor certainly makes sense.
If I were vested in Dewalt already I don't think I'd jump brands just for one tool. I have NO interest in investing in more batteries and charges that are incompatible with what I have. That said, I was given a dead Ryobi little saw that seemed interesting but I didn't want to invest much in seeing if it could be made to work. I found there to be a battery adapter on eBay (can't afford Amazon) pretty cheap and gave it a shot. Even though it's a 20 volt and my Milwaukee battery is 18 volts it all works fine. A little wobbly maybe but it works and I've grown to like it. So if you have batteries for one line there might be options to crossbreed another brand tool. If you must.
