Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
I don't believe so, Neal. From what I understand, everything was normal when they went to town, and they discovered the problem when they returned.Look at the breaker box likely in the half bath. Cycle breakers there, also it's a good reference of what's on inverter vs. shore power as Newmar typically separates them. There is also a master inverter breaker there that people forget or don't know it's even there. Cycle it.
It's likely as mentioned the inverter breaker but there is also a fuse, I think it's in the house battery bay. I remember MapNerd had an issue from overloading the circuit with hair dryer, air fryer, etc. and this fuse got fried, I ordered spares as many did at that time, it's on this forum somewhere. I'll see if I can find it after this post.
Was this even triggered by a high load such as described above or did it just happen when nothing was in use?
Anyone call Newmar advisor yet (number on driver's side window)? Essex line?
Help Dead Battery!
Not sure what happened. We stepped out for the day and came back to dead chassis batteries. We’ve been connected the 30amp service for a week and a half and haven’t had any problems. Honestly I haven’t looked to see if it was charging because everything was running fine. Anyway, everything is...rvforums.com
Inverter fuse size; 300A vs 350A
A recent thread on this forum discussed a 300A fuse blowing in the inverter circuit and the need to carry a spare fuse. I finally got around to checking the value of the fuse in our all-electric 2018 MADP and found that it uses a 350A , not a 300A. Of course, I found that out after picking up...rvforums.com
