Resolved No water
We are in Beaumont add an authorized Newmar repair dealer. They have tested both pumps and they are found to be good. I can’t seem to get pressure to build in the coach. ????
Have you checked the aerators at the end of the faucets? If the water pressure is coming off the pump(s) fine then something later upstream such as your faucets are restricting you it seems.
After 5-6 hours of taking out pumps, checking actual pressures with gauges, putting pumps back in, we have water an pressure back to normal! Disconcerting because we have no idea what the problem was. Very frustrating to say the least.
Yes! You don't know what you touched to fix it!
Knowing would not guarantee the same problem next time. So all is good!!! Glad you got it working.
