TXfreeze
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
The display is out and will not go back on. There is no red light on the black recall box. A search on here shows that seems to be the usual cause. No indoor circuit breaker is tripped and resetting the main and also check the 12 volt cut off. I confirmed there is 110 from the outlet it's plugged into and a test with multimeter on 12 volt, checks out. So it would seem that there seems to be a 12 volt issue. I have not probed the PCB and checked the 5 amp blade fuse. Aafter market PCB is about $40 on Amazon. Any ideas?
