When driving my 2007 Winnebago view for awhile my oil light goes intermittently on and off with “H”.
The oil if fresh and the level is correct. Any ideas
I once picked up a vintage bug, pretty little thing but!!! The engine had been rebuilt. I started having the overheating light come on. By the time I found that the rebuilder had hooked up the oil sensor to the wrong wire the engine was trash. You should be Able to figure the moral of the story!!!
So sensors go bad, oil pumps go bad. Oil thins out when the engine temp goes up. Wires become disconnected, or damaged. Shorts happen. Displays fail. Heck I even had an oil sender develop a leak.
Not really time to continue, rather if you can't fix it, it is time for a mobile, or a tow!!!
