newmarokie
- Oct 8, 2023
- southern oklahoma
- newmar
- Dutch Star 4018
- 40'
- Freightliner
- 450 hp Cummins
- 2017 Colorado, 2013 Dodge 1500 quad cab
I think nearly every post I have made has started with something to the effect "still trying to figure the Dutch Star out". Well, here it is again. When trying to set the automatic generator start based on temperature I am having zero luck. If I even really have that capability, how does the Magnum system get a temperature point for operation? I have adjusted the set point and run time both to no avail. Once it starts, it never shuts itself off. I've tried manual and auto settings as well. I have successfully used voltage setting for auto on/off function. This is not a critical problem I am just trying figure out how it should work. We are moderate temps right now and we should be able to let the generator go quiet at night. I can shut the generator down manually when we go to bed, but if the DW gets hot in the middle of the night, well everybody knows how that is going to work out.
