AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
It only has 300 hours on it. The nearest Cummins dealer is over an hour away. I was hoping to avoid that trip.How many hours on it? I would just take it to a reputable Cummins placeand have it serviced. One morning or afternoon - everything upto date and running smoothly.
Sorry! I am in the forest with marginal service. Long weekend always taxes service,so slow will be my response .UPDATES #4:
We just took it for a drive, stopped somewhere to test the levelers.
We also tried the generator. This time got the Code 41 again.
It seems to alternate between codes 41 and 45.
With that in mind, is there a possibility it could be the controller board itself?
Look in the install manual and follow the 12 volt supply wires. Making sure All connections. Are solid on the 12 v+ + side. Then Make sure All groundings straps and busses/ground points are solid and clean.
So after reading this a few times, I wanted to understand what you were suggesting.Because I know what to expect, I would jumper maybe 6 volts to the brushes and see if the thing produced power. I might even use a lower voltage. That would likely give a voltage way out of tolerance, so the generator should be isolated to keep damage limited. You may find the field voltage in the trouble shooting section of a field manual.
Occording to the product:It wouldn't hurt. My understanding it it protects from corrosion,right?
