- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
OK...the prong spacing on the breaker is the same as a mini fuse. So, apparently, you can easily replace the breaker with the mini fuse. Good to know. I think I will also pick up a replacement breaker or two for the spares box; just in case.I just needed a mini 25 amp and that took care of the problem. Picked up a mini fuse assortment at Advanced Auto Parts. And I'm wondering if the fuse blew because we may have forgotten to turn off the seat warmer in addition to the chair being turned in ways it has never experienced before. ?
That's what Bill did! ?Glad it's working, you should be fine. I was going to suggest moving the driver's seat fuse over to the passenger seat to test it if needed.
I was wondering about that. When I put the new fuse in I noticed that there were 30 amp mini spares in the door, but no 25 amp.Interesting that the cover indicates that breaker-1 is 30A but the device that's installed is 25A.
Probably don’t need spare circuit breaker. First off, given that it’s a circuit breaker it will automatically reset. And if it were to blow, you could always use a fuse in the short term.Thanks for the clarification on the K2-K3 chassis and year differences. We're on a 2018 K3 like @flyboy013, so will pick up a spare circuit breaker or two for the spares box.
Good troubleshooting discussion.
