- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
As I recently upgraded to a Pepwave MAX Transit CAT 18 cellular router and Pepwave antennas, one for cellular and one for wifi, I wanted to design a new antenna mount. The antennas come with mounting accessories to attach to a pole or wall of any sort so this is completely unnecessary but allowed me to do some therapeutic CAD design and 3D printing which is my hobby. I designed an antenna mount which I'll call a "tower" as the goal is to elevate this as I can't reach my airconditioner unit as the top shroud is my preferred mounting location but I don't want to add cable length from what came on the antennas which is 6.5 ft if I recall. In my previous panorama antenna mounts I put them side by side with about 10 inch separation which concerned me a little. This time around I want the two antennas to be at different heights so as not to obstruct any line of site coverage of the cellular antenna by the wifi antenna. Therefore I 3D printed two separate "towers" with the wifi tower being lower so the cellular antenna has a clear view at the mounting plane 360 degrees.
It's ready to mount so it will be put into use soon. 3M double-sided tape will adhere it so the fiberglass roof surface.
Printed with Prusa i3 MK3S using PETG filament (prusament jet black), 15% infill, no supports needed. Print time: 19h
Pepwave Puma Antenna Mount by NealC
This is an antenna mount to go on the roof of my motorhome to hold a Pepwave Puma antenna, one for cellular (taller) and a shorter one for wifi. This will be mounted using 3M adhesive on the bottom of the mount. The antenna can be tacked in with double-sided tape, the included double-sided tape...
www.thingiverse.com
