Power from shore good - NO electricity!
paulsilas
2005 HR Endeavor 36DP 41k mi
Two 50 amp cords totaling 80’ connected to 10’ 30amp cord to house to charge my batteries Confirmed that coach was “absorb charging” 6 weeks ago. I go into the coach (yesterday) and all is dead.
Panel readout:
Coach Batteries have 6.3 volts and charging at 1.6 volts. Confirmed I have 124 volts on each line (L1 and L2) going into the coach. This is the first time this has happened. Batteries in good condition
Questions:
is the distance from house to RV to long?
Why is the coach not charging and no electricity when there is electricity going into the coach?
Appreciate any help. Thanks!
The distance is not a problem. If you were pulling full amperage at some point it could be. You don't have make and model of your coach/camper, so I can't tell you where to look for blown fuses or tripped breakers. You should probably look at your charger or charger/inverter first.
