wildebill308
- Mar 3, 2020
- Home base in the Fort Worth area.
- Mountain Aire
- 2014 CR-V
I was just about to reply as I have friends whose fridges work just like you mentioned. You figured it out just as I was ready to hit send.Well it was definitely a novice issue! I tried all of your excellent advice to no avail, and then had a random thought. I'd been trying to run the fridge on propane but never unhooked the power, both at the house (110) AND at campsite (30A) but what I failed to do is unplug the dang thing and try it that way! Anyway, it works just fine when unplugged lol, I appreciate all of your advice
Well thank you anyway!! I'm truly impressed by all of yall's knowledge and willingness to help!I was just about to reply as I have friends whose fridges work just like you mentioned. You figured it out just as I was ready to hit send.
HMMMM...... Where to start I wonder.It should work when plugged into 115 and propane is selected unless auto is left on. It should try to light 3 times and then lock the board out, requiring it to be reset. It will always default to electric when it is available. You should not have to unplug it. Good that it fired so you know it worked, now to find the problem with the 12v side that is not telling the board to use propane. The system uses 12vdc to work the controls, 115 ac only heats the elements.
There is an Auto mode, maybe I'm just not switching it correctly. I will look at it closer tonight.Look on your control panel, there may be a "auto select" setting. All of my gas electric refrigerators have worked on gas when plugged in to shore power.
