Replacing bedroom slide motor
Well here we are, once again fixing slide motor issues. I have a long history with them and to me there is only one thing that actually fixes them. Wire ties like on an aircraft.
My 2015 DS 4369 had the issue and I had an ex A&E USAF Staff Sergent, that had come out to the coach to do some warrant work for Newmar, do the job. We did all three slides. Six motors in all because at that time the full wall slide was also two motors not HWH like 2016 an above. I know the person that owed that coach after me and he never had a problem with one braking or coming loose.
When I ordered my 2018 I was assured that LockTite was being used on every unit so the issue would not happen anymore. Wrong. One of my slides with electric motors had LockTite but the other did not.
So, we were out of motorhomes for two years, after fulltiming for 7, but we still wanted to travel so I now we own a 2016 DS 4018. And I am in the process of making it right. The bedroom slide has a broken motor so it will be replaced, and all four bolts will be wire tied for safety. I will have the bokts on the other two motors on the kitchen wire tied as well.
LOST IN FL could you plese email me. I see you just did this and would like to talk to you.
vpchianese@gmail.com
Hi to Neal, FL Steve and any of the old HOOT's group on board. Minni Hoots is alive and well. We run it just the the original Hoots, still no fees or up front money, unlike other rallies.
After visiting North Trail to get an idea on cost of labor for replacing the bedroom slide motor (I already purchased the motor from Newmar) and hearing "4-6 hours, at $220+ per. On some harder ones, they cut the shaft and install another coupling" (I didn't hear the exact figure as shock set in), I then decided it was something I'd take a swing at. At first glance, I couldn't understand just how it would disconnect as the shaft goes through the gear box and there would have to be a big enough gap between the shaft ends for the box to come out.
After breaking both trans torque bushings loose, I loosened the set screws on the retaining collars at the bearings and to my surprise, the shafts will slide through the gears to the outside of the box to make room for removal, BUT...for some reason, the floor is cut to clear the gearbox, but not far enough to remove it as the box hits the wood before it is able to clear the shaft.
I then broke out the Dremel and cut the floor a little further to clear the box.
At this point I had to also remove the bearing mount to get enough wiggle room to remove the motor.
Finally, the box was able to be removed! I was so pleased, I took a day off.
After that, it was just a matter of reassembly with the new motor and Stage8 fasteners. (didn't install the clips yet in the pic) A word of caution about the torque couplings. When first breaking loose, they will move a bit then tighten up again. You have to beat on the coupler housing and shaft to loosen the pawls in the coupler until the nut will rotate out. Not doing this will break the inserts and require replacement. I actually soaked them with Blaster the day before to make them easier to remove. I cleaned them with brake clean before reassembly. I'm pretty proud it turned out ok and actually works, but more so that I didn't loose a pint of blood doing it.
Just think of what you made (saved) per hour.
Great writeup. Saved for some future dark day. Checked mine again in the fall - all was good, although that inspection is of course only valid for ± 1 week.
Been out today with shoulder surgery. 🤢 Sent an email.
