DavidL
RVF VIP
- May 8, 2021
- Metamora, MI
- MountainAire
- Spartan K2
- Cummins 500hp
- 2023 Corvette
The slide toppers were getting really ratty. Torn, dirty, perforated. So, time for new ones. Amazon had a good price for bulk material. Bought two rolls. Pulled the old toppers off and powerwashed the RV, and the aluminum slide protectors to clean it all up.
Opened up the box and cut to length with a drywall right angle and a sharp utility blade.
Started to feed the cord into the slots...oh crap...the cord is slightly too large diameter. Upon research...mine are an older, smaller diameter cord. And I already cut the bulk fabric to length so can't return it.
So what to do?
Hmmm, the parts are all extruded aluminum that the cord slides into...what if that was stretched out a bit. So, I fabricated a "Fid" out of a piece of threaded rod. Ground the tip down a bit to fit into the extrusion channel. Then, brazed a scrap piece of metal to hold onto the fid and to hammer. Worked pretty slick. I banged it all of the way down the length of the aluminum and widened up the channel just a bit.
Then, I was able to get the cord into the new channel...but it was really tight. So, crafted a way to pull the cord / topper down the channel. Clamped some wood to act as long "pliers" to get lots of traction on the fabric without damaging it. Then, used a ratchet strap to pull the fabric. With so much length, there was a fair amount of friction. So much so, that the aluminum started to bow with the pulls. So, clamped a 2x4 down the length to make it more rigid.
Put some wiring water soluble lubricant on the cord to aid.
After about 10 minutes, the fabric was down the length are ready to put back on the RV. Thankfully the channel on the RV was the proper size so the fabric slid in nice and easy. I retorqued the topper windup spring to ensure good tension. Wound up nice and smooth and flat when the slide was pulled in.
So, it looks like new again and another project off the list.
So, the lesson is double check the cord diameter is right for your motorhome (both sides) before you cut the fabric
So what to do?
