- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
I noticed that after I upgraded my model # …I would just remove the lettering altogether, luxury line doesn't use them.
I've threatened to do this with some sort of red line but dots would be great! Where do I get the red dots?Another cheap easy one for those of us with analog gauges, putting dots where the gauges would normally be when all is good while driving. just a glance tells you all is good, or not. View attachment 163
Never mind, J&JD. I read a little further and found the link.I've threatened to do this with some sort of red line but dots would be great! Where do I get the red dots?
Where did you have brass water quick disconnects?I had the brass water quick disconnects replace with plastic Banjo-type fittings and like them a lot better and there is no restriction of water flow.
Then I use these to keep the critters out.
On my black tank flush hose, my water connection to the coach, both ends of my external water filter, and on the Y connection on the pressure regulator that hooks to the campground water supply.Where did you have brass water quick disconnects?
