Roadtrek RS Adventurous Electrical Diagram
mtatkow
Have been working on cross checking and updating a wiring diagram for my 2018 built on a 2017 Sprinter (which should be the same as similar years). Mine has the outback package with no propane, UHG, diesel Alde, dual solar systems (total in the 470w), Voltstart and two 3000w inverters, one for coach, one for galley. So far I have done a reasonable amount of cross checking but am not complete. The attached diagram is based both on what I know and a diagram dated 2019 from KS2 that I have in hand, but is not yet fully verified. Per a recent back and forth with Roadtrek (who qualifies their responses by stating the obvious - they are not the same "Roadtrek" that built my van in 2018). The van is put away for the season and I will not get back to this until spring.
Looking to see if there is any interest in me posting my results to the forum as I go along. When complete with my verifications I intend to add some more battery to the AGM side while maintaining the existing pair of 200AH ecotrek modules, with eventual goal to replace the modules with more standard hardware.
OOPS - I posted the KS2 diagram instead of where I stand. One item to note - I replaced the antiquated blue ray system with a 5.1 amp with its own bluetooth and the TV with a more modern Fire TV. You will see a small 150a inverter for the new amp (which is actually 300w - a typo) so I can run the sound system without having to turn on the inverter. Reduces some of the system losses while not plugged into dock power.
Only the pair of 200ah ecotreks and the AGM.
Keep in mind that it is a rare RV/motorhome that can boondock without a generator (shore power) for more than a couple hours if large loads such as AC are used. [Lets leave the ecotrek Voltstart system out of this discussion for the moment - only complicates what I note below]
The system was not designed to support the sum of all loads. The battery BMS controls will cut them off long before the required amperage is hit. It would take at least double the modules. Even then, running 6000w would eat up 4 modules, even if I had them, in just a couple hours max.
Each inverter is sized and designed to cover its connected downline load. The galley equipment is dedicated to one, the AC, electrical Alde heating (if enabled, I almost never use this - I use the diesel almost exclusively), plug loads and TV on the coach inverter. A very robust design once understood.
When on shore power the 30 amps feeds via an integral auto transfer switch in the coach inverter all 120v loads normally served by the coach inverter, which them becomes the charger for the lithium modules. (The 470w solar is in addition to the inverter charging capacity) The galley 3000w inverter covers the oven and induction stove (intermittent short duration loads) fed by the batteries. In this manner the sum total system can cover intermittent loads that would normally blow the 30a shore power breaker. Clever. If you are using a generator - this design allows you to use a smaller unit with minimal care - especially if you install a soft starter in the AC.
Any mods I make to this will be to further improve boondocking duration and reduce the heavy parasitic loads present in the ecotrek / KS2 design. There is more to this discussion, but this covers many of the high points of my discovery thus far. One interesting point that may or may not be specific to my coach - both my inverters are identical (3000 watt with integral ATS and battery chargers)- however the ATS and charger functions in the gally inverter are inactive due to how things are wired. It appears that in an emergency loss of the primary coach inverter one could swap these and get things back on line rather quickly.
I am not sure what I am supposed to keep in mind.....that was long. I built my system and understand the need for a generator. I was just inquiring about what they intended with no amp hours and 2 3000 watt inverters. Robust it may be but it is a factory package meant to sell to people who do not understand it's shortcomings. Which you obviously do! Carry on....
The number and size of the inverters is pointless if there's no batteries to invert from...
The intent by Roadtrek / KS2 was to create a "green" coach (not my intention or politics when I got this thing, just explaining) which permitted purely electrical operation during many commonly encountered conditions. I have easily gone boondocking for several days using just the batteries. When I do so, I avoid use of AC. When I do have shore power, this system can run everything without fear of blowing a 30a service - it is pretty rare to run the oven and / or stove for more than 20-30 minutes. You then have the operation of the solar, Voltstart controller and twin alternators (includes the 300a dedicated to the coach systems) under the hood to consider, so if the system does get drawn down it can be bumped back up pretty quickly.
What I don't like are parasitic losses in this system. These are substantial in the ecotrek modules based on their design. I have not confirmed on my own systems yet, but if the reports are correct, simply turning on a module with zero loads connected can cause it to drain down in less than 2 days. Use of the inverters also has parasitic loss, thus why I installed a high efficiency 300w pure sine wave inverter dedicated solely to the sound system and TV rather than having to run the larger unit.
This is off the original topic already, it was never intended to be a discussion of the merits and faults of this system. My question was whether anyone would be interested in me posting a confirmed diagram of my findings as I go along and, perhaps, of my ongoing efforts to remedy some of the shortcomings. I personally think there are both clever and rather dumb design points in this system and the engineer in me, now retired with time on my hands, can't help tinkering with my toys. Disclaimer of course will be "use at your own risk, your results may vary".
