Seperator Warps Battery - No Room for DC-DC Charger
skibum42
I’ve cooked two sets of Trojan T-105 house batteries in my 2013 RoadTrek Adventurous RS on the Sprinter 3500 chassis. The stock battery separator lets the alternator dump way too much current (like 45 amps) into them while driving and warps the core. The Trojan's don't want more than 25 amps.
A DC-DC charger would solve the high-current issue by capping the charge at 20–25 A, and give me a nice charging curve, but I can’t find a good place to mount one. Most are 9″ or more and want a few inches of space around them. The area around the battery separator is too small for the DC-DC charger and I have concerns about the heat under the engine hood. The only spot I see is on top of the air filter box, which I’d rather not drill into.
If you’ve put a DC-DC charger in a Sprinter 3500, where did you fit it? Or have you had my battery issues and solved it another way? Pics and tips welcome!
I have a 2014 CS Adventurous with what might be the same setup as yours. If so, there are connections on the back of the separator. Unplugging the one marked 'ground' will disable the battery separator. Not a fix, I know, but it can be done quickly and without tools, as the the connectors will just slide off. use a mirror if needed to peek behind the unit to identify the ground connection. As for your idea of using a dc-dc charger, I don't have a recommendation either for or against using one. I am using lifeP04 batteries with a dedicated 2nd alternator now and it seems to be okay.
Typically plates warp because you let the charge state go below 50% discharge. However if you want to limit current to your house batteries you can get a power diode to do the job.
This works by lowering the incoming voltage by. .5 volts effectively reducing the current. Be warned that 13.9 volts in will extend charging time considerably.
However as stated above. Your problem is more likely due to over discharge.
Kevin, Power diode? What does it look like? How much current can it handle? Tell me more please. You mentioned this in another post (Is complete lithium possible?) and I thought you were talking about an isolator.
