Several Overhead LED lights on 2015 Roadtrek Adventerous CS not working after power surge
capt.tractor
Had the rig hooked up to 30 amp service and everything was fine until the power interruption by electric company . Noticed overhead roof fan not working and about half of the overhead LED lights out.. Checked all fuses. Looked good. Swapped out lights and it is not the bulbs. Any suggestions on a hidden fuse that might be the culprit ?? Thanks Neal
assuming you are on shore power, check the shore power breaker. If the breaker is good and if you have a meter, check both legs have power.
If you are on a double pole breaker one leg might be out.
