Shore power
dalerees
after my battery is removed for winter can i still operate on a/c power? would like to put small fan inside for winter. is a solar system.
Yes, BUT.......ensure your battery leads are insulated to keep then from grounding out to the chassis.
Roger
Your profile does not list the type of RV you have. My question to you is, does your RV have a Battery Minder? If it does, your batteries will probably be better off if you leave them in if you are hooked up to Shore Power (even if only a 15 amp service).
Darrell
Darrell
Hi...winter temps here often reach -25 C. is recommended to store battery where is warmer i.e. garage in my case. shore power is only to run a fan for air movement, on a timer. electricity is expensive here. thanks for the feedback.
Dale.
