turbopilot
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV, 7.2 kW Propower Generator
I thought I would start a discussion about possible modifications to the Newmar charge splitter/battery isolator design used in SilverLeaf equipped coaches. I will lay out my thoughts for discussion but I am still looking for input and other approaches. The primary driver is that the Newmar charge splitter/battery isolator design is pretty old fashioned and prone to failure. A further driver is that this design is a bad idea with lithium batteries in the mix. Given demands of the lithium batteries it can put excessive load on the coach alternator without regulation. And lithium batteries really like tight computer controlled algorithms for charging. The present system does not do any of these things.
Here is how I understand the system works. I have pulled this from other threads. It sound plausible. So what we have is called a "Voltage Sensitive Relay" charge splitter/battery isolator design. When the engine is running Silverleaf senses a chassis battery voltage higher than the house battery (this gets messy if solar is online) then opens the charge bridge to allow the diesel engine alternator to charge the house batteries (in addition to the chassis batteries). As far as I can tell this is a full passthrough of alternator output to the batteries with no regulation or charging algorithms applied. With either battery type and a low battery SOC this can really place a high continuous demand on the alternator.
Here is what I have heard is going on from several sources and my own experience watching the charging cycles of the chassis battery.
When the engine shuts down the charge bridge closes (no flow) isolating the chassis battery from the house battery. When the chassis battery falls to 12.5 or lower for 30 seconds the charge bridge opens to allow the house batteries to charge the chassis batteries. Some sources say this may last at most an hour or until the chassis batteries hit around 13 volts. If there is a charge source on the house batteries the cycle will continue opening and closing the charge bridge based on chassis battery voltage. The constant opening and closing of the charge bridge solenoid is the cause of flaky SilverLeaf behavior without the fly back diode.
This whole system exists to do three things.
1. Open a line to the alternator when the engine is running to charge the house battery and supply DC needs of the coach.
2. Charge the chassis battery periodically when the engine is not running.
3. Provide a switch to allow current to flow from the house battery to the chassis battery in the event of a discharged chassis battery.
There is a better, more modern way to do all this.
My last New Aire on a Freightliner chassis had a big chassis battery shut off switch near the chassis batteries. Assuming the design has not changed the cable from the switch goes forward to the charge bridge solenoid mid ship. I am thinking about replacing the charge bridge solenoid with a Victron Orion - Tr Smart DC-DC charger. The largest Orion DC/DC charger is 30 amps so with a large set of lithium batteries may two or three chargers running in parallel that may be better to charge the batteries faster. The decision comes down to how fast to charge the batteries versus running the alternator at high output for a long time. These Victron chargers are controlled with Bluetooth via an app so you can elect how many chargers to keep on line.
So this would eliminate the need for the charge bridge solenoid. In the event you want to start the engine with from the house battery you would turn on the chassis battery switch otherwise it would remain closed with charging coming from the Orion DC/DC charger bypassing the switch from the alternator to the house battery.
All that is left is the ability to trickle charge the chassis battery. As I laid out above SilverLeaf is intermittently opening the charge bridge with the right voltages when the engine is off to keep the chassis battery topped off. There is a better way to do this without cycling a solenoid.
Xantrex makes an echo charger just for this purpose. This little trickle charger runs all the time keeping the chassis battery topped off using the house battery even when there is no charge source to house battery. If the coach is parked outside the chassis battery has a solar cell for charging. The solar cell in bigger in 2023/2024 models. So it is possible the solar charger may keep the chassis batteries topped if the coach is seeing the sun each day with the trickle charger.
So those are my thoughts about eliminating the charge bridge solenoid. Aside from avoiding the previous problems with the charge bridge the biggest upgrade is that lithium house batteries and the engine alternator will be treated much better. This is an important consideration.
Thoughts?
Thoughts?
