Rd1
RVF VIP
- Feb 16, 2022
- ̶N̶e̶w̶m̶a̶r̶
- ̶L̶A̶D̶P̶
- ̶F̶L̶
This would be a pretty major modification of the DC electrical system. I would rather do it myself. I will wait to see what is actually in the new coach. They have been changing components but I think the basic design is unchanged.You know, one way to deal with this issue, is to request the change in your custom order. Even though, it'll likely get denied, it'd help, if more people made an effort to ask for it. They'll eventually come around to implement it.
Thanks for waking up this thread. Where is this solenoid located?Waking up this thread again apparently the charge bridge issue continues in SilverLeaf equipped coaches.
Good post by Art from SilverLeaf on "the other forum".
New Aire 2022 Bridge Solenoid Problems
I have a 2018 NA 3343…..I am about to pickup my new 3543 NA in October. The issue with the White Rodger original charge bridge in my current DP for those of us that bought the early NAs was ridiculous and frustrating until the culprit was found. In a conversation with Silverleaf yesterday it was...www.irv2.com
I can't believe this system has not been redesigned after all these years and all the gremlins that can be caused with this ancient solenoid technology acts up.
In the New Aire it is mid ship behind a panel just aft of the DC electrical bay. Not easy to get to. I installed a fly back diode on the solenoid in my old NA.Thanks for waking up this thread. Where is this solenoid located?
Thanks. I suspect that I will need to have a diode installed as I've been watching the dynamics of my house and chassis batteries on my SL for a while with not a lot of understanding of what is going on. This thread helped a lot. Thanks again.In the New Aire it is mid ship behind a panel just aft of the DC electrical bay. Not easy to get to. I installed a fly back diode on the solenoid in my old NA.
The problem now is that these lithium batteries need more care and apparently bugs do remain in the current (old) design. Several reasons to consider a modification to the old design.
The folks at SilverLeaf understand the issues better than Newmar. Apparently letting SilverLeaf take control of that charge bridge was left over from the early days when SilverLeaf was first introduced on the KingAir. Not much has changed since but with lithium taking over it is time for a change.Thanks. I suspect that I will need to have a diode installed as I've been watching the dynamics of my house and chassis batteries on my SL for a while with not a lot of understanding of what is going on. This thread helped a lot. Thanks again.
Have not kept up with Silverleaf but yes the old system needs to be replaced.Didn't Lippert acquire Silverleaf? Someone did, so will engineering continue or is it in maintenance only mode? How does the VEGA system Entegra uses compare? Maybe Newmar needs a new system?
I suspect that I will need to have a diode installed..
I read that another 2022 LADP owner has the Trombetta solenoid so I want to confirm. I hope you are right though.The LADP likely has an Ametek solenoid
Thanks, gonna go look now.The solenoid is located in the power compartment right behind the power cord. you have to remove the black panel (Velcro attached), to access the solenoid. the unit is located on the top right of the first pic. 2nd one has the part no (140045) to see if you have the ametek.
The LADP likely has an Ametek solenoid, see pic for location and part number. Ametek has the diode. the original white rodgers were the ones requiring an addition of a diode. some newmar model still use that! The solenoid is located in the power compartment right behind the power cord. you have to remove the black panel (Velcro attached), to access the solenoid. the unit is located on the top right of the first pic. 2nd one has the part no (140045) to see if you have the ametek.
Well, darn. I have the trombetta. Looks like I need the diode kit. Has anyone installed one? If so, do you have a photo of what it looks like? Thanks.
Thanks @turbopilot. Looks like I can add that to my list for Newmar.Yes, I installed one on a White Rodgers solenoid in my old NA. It is in a hell hole back there. Was not an easy job for a simple diode.
It also exposed the simply awful electrical wiring fit and finish conveniently covered with these panels. Note the module loosely held in place with some zip ties.
