Slideout locks not locking when side in
Roadglide117
RVF VIP
North Lima, OH
Ventana 4381
400 Cummins
28' car hauler or 2019 F-150 4x4 Sport
I'm trying to help my brother figure out his slide lockout arm problems. 2019 DS passenger slide living room slide. They do not lock for travel when slide is in. We've been traveling the last month with no change. Forward lockout makes a noise for couple seconds after slide in but nothing is moving. Rear lockout makes no noise. We did stop at mothership on way and bought sensors. Just throwing it out there if something else that could cause this? The control board has been changed out before trip. They weren't working before this either.
Thanks for any response.
With slides out, check the paddles at the bottom forward and aft end. Lubricate them!
With slides in, look at the white locks from the inside that open to push against the wall, activated by compressing the paddles mentioned above. Make sure they are tight, I had one loose in the attachment to the top of the slide.
good info here from Dutchstar Don - maintenance but also helps to understand the system.
Looking for a drawing of the lock flippers, rods etc that I received a while back.
Thanks Neal, I have not checked the white paddles inside - good point!!
thank you..will check that out
I had a slide lock not working on my living room slide. I ended up jumping the power wires (black and red) behind the plastic cover and was able to activate the lock out, switch the polarity to make it go in. if you get no response then you know its the motor.
Finally had time to check my brothers slide out problem. The motor on the forward slide had come completely apart. All screws were out. Put them back in and now both sides lock normally when slides in.
