Rich-MLsRV
- Oct 1, 2020
- Colorado
- Ventana
- Freightliner
- 2020 Jeep Cherokee
Folks,
I am considering using AMsolar solar panels. I like the AMsolar panels since they use VHB tape for mounting and hence don't need to drill into the roof. Folks that have used the VHG tape method for mounting have not had a issue w/ the panels detaching. I am planning to have 6 solar panels configured 3 parallel sets of 2 series panels.
I think in selecting a panel one needs to consider the voltage drop from the roof to the batteries and the solar charge controller base on voltage and current into the solar charge controller.
For the GS200 (price $299/panel including mounting hardware and wiring) I came up with
Voltage drop: 0.58
Voltage drop percentage: 1.44%
Voltage at the end: 40.04
For the ZS190DJ (price $525 / panel including mounting hardware and wiring) I came up with
Voltage drop: 0.28
Voltage drop percentage: 0.34%
Voltage at the end: 81.52
My thinking is it's hard to justify the more expensive ZS190DJ when looking at the voltage drop from the roof to the solar charge controller / batteries in the basement. The ZS190DJ, because of the higher voltage / lower current into the charge controller, would need a cheaper solar charge controller. Victron MPPT 150/85 for the ZS190DJ and Victron MPPT 250/100 for the GS200.
Are there other considerations I should be taking into account in selecting the solar panel?
Thanks
Details are below in case you wanted to view my calculations
The panels I am considering have the following specs.
GS200
and ZS190DJ series configuration
I calculated the voltage drop from the roof for each of the panels
GS200 with the series / parallel I mentioned above
For the ZS190DJ
Voltage drop: 0.58
Voltage drop: 0.28
Thanks
GS200
For the ZS190DJ
