I recently added a Grape 190W panel for $218 and a Renogy 100W panel that cost $104 Much cheaper than the Zamp panels with the same output and same durability. I bought the feet separately and AMsolar sells some for different panel frames, 35mm or 40mm. I already had two Zamp 100W Obsidian panels and they provide no advantages over the Renogy panels that cost a fourth as much.
It helps in terms of output to have the panels elevated above the roof for some amount of cooling of the cells. How much above the roof is subjective. In addition to the size of wire used it is also worth keeping the runs as short as possible. The poor installation job done by the people at the Winnebago factory put one Zamp panel to far to the rear and so need to be moved and the installer used the Zamp kit wiring and did not shorten the cable so I had and extra 8 to 12 feet of cable from the panels to the roof cap from the panels.
I do highly recommend the people at Amsolar that go out of their way to work with their customers. Another good source for solar items is RV Solar Store. A great installer for any RV is www.Offthegridrvs.com which is also a Lithionics lithium phosphate battery dealer located in Parker AZ.
