FL-JOE
RVF 1K Club
 - Nov 15, 2019
 - Frostproof, Florida
 - Forest River (sold)
 - Salem FSX 270RTK-X
 - 2022 Ford Expedition Timberline
Of course it was assumed that anyone with a “brain” would know that the bags must be filled. Obviously I did not communicate properly. The conversation was concerning the jacks, and that was the assumed the bags would be full. Glad to have made your day for your “No Brainer”.
Nope! I have to leave the engine running when I pull into a spot, hook up electric, let the slides out, then drop the jacks, then turn off the engine.
I have tried ACC position several times and I get nothing on the jacks. I assumed Newmar wired it that way to strongly encourage me to be on air when putting the slides out.
Standards. Who needs em?My jacks work with the engine off or running in either ACC or IGN position. However none of my slides will work in either direction with the engine running. It amazing how many different combinations there are for these two systems.
Spartan also recommends this and it has helped me a great deal along my travels. Sometimes when sitting a bit, the secondary sit tank can get real low and so if you lift jacks first, you may have issues airing up. By leaving jacks down, you give the secondary air tank time to fill. The alarm is annoying, but it does make a difference.They suggested starting the engine before raising the jacks.
FL is not in conflict with Newmar. You leave jacks down to give the secondary air tank time to build up pressure, then when airs up, raise jacks. You will lose some air so let it build again. Turn off motor and bring slides in.Yes I do. I just wished Freightliner was on the same page. Newmar has changed the sequence but Freightliner does not agree. One builds the chassis. One builds the house.
The conflict that I was referring to was the sequence for jacks then slides vs slides then jacks. FL still recommends jacks first. Since my last conversation with FL I have been starting the engine with the jacks down to build up the pressure. I was in the coach again this weekend and it worked like a charm.FL is not in conflict with Newmar. You leave jacks down to give the secondary air tank time to build up pressure, then when airs up, raise jacks. You will lose some air so let it build again. Turn off motor and bring slides in.
Ah gotcha. Well, I like to air up with jacks down, but I'm not bringing my slides in til I'm aired up like Newmar taught me at CPU.The conflict that I was referring to was the sequence for jacks then slides vs slides then jacks. FL still recommends jacks first. Since my last conversation with FL I have been starting the engine with the jacks down to build up the pressure. I was in the coach again this weekend and it worked like a charm.
Well, I used to have problems airing up. The gauges would say I had the correct pressure, but when I did a visual check, I was not aired up. Spartan maintains that by leaving the jacks down while airing up, it helps the secondary air tank fill especially if you have been sitting for a bit. I don't know all the mechanics, but Spartan does instruct people to air up with jacks down and I can verify that it has eliminated my airing up issues.It seems some of you are mixing the two systems. The reason of running the engine to inflate the airbags is simply because the air compressor runs off the engine and will replenish the tanks faster after the airbags use the air to refill themselves to get back to ride height.
