RKins
RVF Expert
- Nov 15, 2019
- Sarasota, FL
- London Aire
- 40'
- Spartan
- 6CTA 8.3L Cummins.
- 2008 Jeep GC Overland
@ARD "At the beginning when I was having issues with airing up, Spartan would also instruct me to cycle through the jacks. I don't really get the connection, but evidently there is one."
If you have HWH jacks, there is (at least was) an interconnect between the HWH system and air tanks. When you "auto level" it dumps your tanks as part of the leveling process. If you interrupt the "store" cycle of the HWH system you may not be able to air up - I learned the hard way. So that being said, if you have problems airing up, press the "Store" button on the HWH panel and let it complete the cycle (even if already stored) - it releases the connection that dumps the tanks and allows them to fill.
On my old coach if I try to start the coach while the jacks are down I get blasted with a horn from under the dash. I put the key in the ACC position when using the HWH system.
